5.0 NCK Eng spec;
Compression; 8.9 – 9.0 to 1.
Bore; 94m/m
Stroke; 90m/m
Cam; Kent Cams
295 degrees duration
Cam lift = 6.98mm
Hydraulic profile
Valve Springs; Duel
Heads; Gas Flowed, Ported and - polished c/w big valves
Inlet Valves; 1.700” dia
Exhaust Valves; 1.450” dia
Inlet Manifold; Gas flowed
Pistons; Cosworth
Piston Rings; Land Rover
Plugs B7 ECS
ECU; 500 Cat Chip
Tune Resistor White
