Water pump differences.
SuperV8 wrote:Regarding the height I used the RR water pump on my Dax Rush (even though most people were struggling to source SD1 front covers/pumps) with no problems and I had to cut a hole for the plenum to poke through so i'd have thought the SD1 would have a higher bonnet line as the plenum fits under the bonnet!
The SD1 slopes down quite steeply to the front - just guessing, the top of the rad is about 3" lower than the plenum. The RR more or less parallel to the ground.
Robrover
Post by Robrover »
I ditched the SD1 pump and fitted twin thermo fans with their integral plastic shroud (off an AU model Fprd Falcon 1998-2002) which pull a massive 3,000 cfm of air through the radiator.
Along with a Buick 300/340 water pump which is shorter than the SD1 pump.
GMB, AC Delco, TRW, Cardone and Airtex all sell these water pumps which are around USD30.
Robrover wrote:I ditched the SD1 pump and fitted twin thermo fans with their integral plastic shroud (off an AU model Fprd Falcon 1998-2002) which pull a massive 3,000 cfm of air through the radiator.
The version of my SD1 takes a temperature sensitive viscous coupled fan which seems to be as used on many new cars these days so I'd guess is the most efficient route. I'm happy enough with the cooling system - it's just the cost of the pump, since it appears to be getting rare. Still cheaper than converting to a decent electric fan set-up, though. ;-)
ged
Post by ged »
Interesting piece of information. I had a quick google & came up with this.:D
http://www.gomog.com/allmorgan/pumps.htm
Robrover
Post by Robrover »
Yes the Buick 300/340 alloy short nose pump is the one I have along with an EH model Holden (1963-65) pulley which lines up with the SD1 crank pulley.
I don't use the SD1 alternator bracket, made my own up.
Almost all new V8s and sixes here now use thermo fans to cope with the hot conditions encountered in summer when idling for long periods in city traffic (along with 2 core alloy radiators).
To switch the fans on and off I used a Flex a Lite Variable Speed Controller from Summit Racing.
ged
Post by ged »
Hi Robrover,
I've also gone the electric fan route with a thermo-switch. Summer or winter the temperature sits between 85/88C. It also makes tensioning the fan belt etc easier as you don't have that bloody fan scraping the skin off the back of your hands.:lol:
Regards Ged
ged wrote:Hi Robrover,
I use a turnbuckle to tension the belt on my EFI - the design of the alternator bracket makes it difficult to lever it to the correct tension.
Couldn't find one exactly right so cut down one from here:-
http://www.steelwirerope.com/Products/C ... Range.html
Look at the eye & eye range.
ged
Post by ged »
I use a turnbuckle to tension the belt. So did I Dave. Remember this?:wink:
Regards Ged.
Return to “Cooling Area”
