kiwicar wrote:If you have the budget to change to Merlins then yes they are a very good base for further modifications and will give you more power straight off, I would also renew the cam at the same time, however this is a little tricky to advise on wether you want an upgrade of cam or stick with the standard one as you haven't as yet said what sort of use you put it to.
One issue here is the LPG, this requires more CR than petrol, and merlins will let you run more CR with petrol without detonation, they are also a high swirl head wich will also help the LPG burn quickly, however you can't increase this much without a change of piston.
I am not the best person to advise on LPG as I hate the stuff
The Merlin are expensive but i do not want to swap from Stage 2 to Stage Merlin's later. That would be even more expensive.
Some known vendors proposed me Stage 4 heads too. I don't really know how to make the choice between Merlin or Stage 4.
About the cam upgrade, is there any that could fit with stock heads in order to wait and save for heads?
I'm looking for a at least 40-50 hp gain at the end of those mods. 300 hp final would be perfect but since the Rover V8 costs a fortune to be tuned, i may prefer to swap it for a GM LS1 engine like Overfinch did.
I'm looking for some more torque i guess.
I feel the Range Rover being sluggish before the 3000 RPM level.
I use my Range Rover in every situation except city.
It does offroad, long highway travel, expedition travel...in fact everything that a Range Rover should normally do.
Sorry for that last maybe dumb question. Does the head modification has an effect on fuel consumption? Except the fact that if i have more power i'll press the pedal more (or maybe less, who knows?)
Best Regards
Flo
