driving a 302w oil pump?
hi people in my computer, how do i drive the oil pump when using coil pack ignition? ford 302w with no dizzy, do i have to cut down the shaft somehow? any info appreciated, cheers, glen
i WILL finish it!
the easy way is leave the dissy in situ and use it to run the pump, but you cam on a Rover cut the top off the dissy and fit a shaft retaining system, so basically you have a stub of a shaft held in the bottom of the dissy body that then fits to the spur gear and still drive the pump
THE SMOKING GNU
Re: driving a 302w oil pump?
I asked the same question on TurboMustangs forum and was told that I could use a Ford Explorer camshaft phase sensor.glen wrote:hi people in my computer, how do i drive the oil pump when using coil pack ignition? ford 302w with no dizzy, do i have to cut down the shaft somehow? any info appreciated, cheers, glen
I got one from U.S. Ebay and have just been down the shed to take a picture
Still quite long, but not as ugly as an unused dizzy.
I might try to make it shorter when I get the spare time.
Mark
On the RV8, does the dummy need the shaft retained at the top? Or is it ok to just let it rest on the pump drive? I reckon the gear action will tend to push it upwards, so should be OK when running, the thrust being on the bottom of the dizzy body as usual.ian.stewart wrote:the easy way is leave the dissy in situ and use it to run the pump, but you cam on a Rover cut the top off the dissy and fit a shaft retaining system, so basically you have a stub of a shaft held in the bottom of the dissy body that then fits to the spur gear and still drive the pump
