Where should I vent the 2 vents on top of my rocker covers to?
Just feed them over the side, or into a filter or back into the carb??
Rocker covers Vents ??
Be very carefull as the leg you bite today could be attached to the arse you have to kiss tomorrow.
Re: Rocker covers Vents ??
You need to clarify what set up you have. eg. Carb type , injection, and from which model the rocker cover are from.Chorlton wrote:Where should I vent the 2 vents on top of my rocker covers to?
Regards Denis
I agree that this is the simplest way to achieve passive crankshaft ventilation. For positive ventilation, you would need to fit a PCV valve and connect one of the rocker covers to the inlet manifold and the second rocker cover should then have a small filter fitted.gelmonkey wrote:I run my breathers into the base plate of my filter and it works just fine.
cheers
P
It seems to me that the rocker covers in question are the P5 or P6 type as the SD1 covers I have don't have two breather connections.
Regards Denis
