4.6 Crank
need4speed
4.6 Crank
Post by need4speed »
Offered up my 3.9 flywheel to my engine to discover that the 4.6 crank has a locating dowel in it for the flywheel. What is the easiest way to remove this so i can fit my own flywheel?
hacksaw or grinder mate,
had to do the same thing on my 4.6 crank
Teesdale_landrover
Post by Teesdale_landrover »
best thing to do is weld something to it, such as a bolt and use a slide hammer to extract it
V8 Classic rangey builder, tdi destroyer
Post by ian.stewart »
another way to get it out is drill and tap it all the way thru then you can jack it out with a bolt
THE SMOKING GNU
need4speed
Thanks for the replies fellas. Think ill run a tap through it and use a bolt to push it out.
sidecar
Post by sidecar »
Just hack-sawed mine, it's soft as sh1te! :shock:
