I gave up looking for a Mk1 or Mk2 Transit, as finding a good one for sale here (I wanted LWB) is almost impossible.
It is a 1995 LDV 400 V8, ex Police, and this one is a 5 speed with the LT77 box. Kind of rare in that it is:
-a panel van
-has only done 53000 kms (30 000mls) from new
-has virtually no rust in it!
-still has the protective plastic on the door trims - it is REALLY tidy!
I have given it a tidy in the engine bay, and did some baseline runs on the dyno before some "tuning" work commences! Initially it made 102 hp at the rear wheels, and after trying several different settings on the ignition timing ended up at 108 at the rear wheels - pretty good increase for no expense! I have since removed the factory fitted restrictors in the intake and exhaust, and will run it again on the dyno to see where that puts us. These run the 3.5L Rover V8 8.13:1 engine on SU's and make around 125hp stock at the flywheel, interestingly this van has the later crossbolt type block, but without the crossbolts. The oil pump is also the early style, and drive is by V belts instead of serpentine. I might possibly go to a 3.9 or 4.6 engine later for a bit more torque, we shall see. It has single leaf tapered springs on all four corners (yes beam front axle!) and the big four pot AP front calipers as per Rover Vitesse.
Kind of an ugly old thing, but it sounds great and goes like hell for an old van!
Conrad
