I would bin the idea Adam, you've no chance of fitting a siamese plenum under your bonnet. Even if you could get the plenum under the bonnet line you would need to cut holes for the hose(s) to fit which wouldn't be pretty, plus you won't have enough room for 2 air filters.adamnreeves wrote:Nope, but my trumpets are already lowered and half expecting to have to cut down the plenum also but I shall leave that until the engine is in the car and I can see how much I need to remove.
pitsnow wrote:Are you sure you will get this under the bonnet of the Westfield?
It would not on a Rush.
Rear facing really is the only way to go. I bit the bullet and bought a carbon plenum for mine
I don't know anyone who has fitted anything other than the factory cut n shut rear facing or the ACT carbon version. I know the Dax Rush demo car had a std plenum but that stuck out of the bonnet.
