I have the 4 main wires connected, 12V, ignition, fuel pump, and 510ohm ground (auto to manual trans).
The motor turns over, there is spark and I have approx. 37lbs fuel pressure at the rail.
My problem is the injectors are not opening. I pulled the fuel rail with the injectors attached and grounded pins 11,13, and 16 with the ignition on and the injectors open but they are not opening under normal circumstances.
What could be causing this? Im stumped and would like to get this thing going! Thanks for any help
Follwing are a few pics of the swap.
Cheers -Donovan
