It has a starting handle dog on the front pulley and heater take off pipes (I think) near every spark plug
Not the best pics I know but I'll try and get an engine number at the weekend..
Thanks for the engine info, that sort of ties in with what I do know about it. Looks like I'll be keeping it for a spare and using my high compression 3.5 which has a few more hp I think.kiwicar wrote:Now can we play "guess the chassis?" please.
It's bolted to two large 'L' fuel tank brackets which are bolted through the wall with large metal plates on the outside to spread the weight. The compressor is rubber mounted so no vibration through to wall and it is also reasonably quiet. Should have been a little higher though so as we could have a bench underneath it.topcatproduction wrote:I take it that's fixed on well- otherwise it would have vibrated the rawl bolts out by nowHairbearTE wrote:I like the wall mounted compressor![]()
