Can you ever have too much gas
I was only running 60hp more gas than usual. And I retarded 2 more degree's to compensate.
I've just found my BIG FAT SPARK from the MSD and Blaster coil is not as it should be. In fact, its not as strong spark at all. If I crank with the coil lead off it normally jumps nearly 3" from the coil to the bodywork. Now it dont?? I could just about get 3/4" when I tested. And using a spark tester at 30 thou gap it was still a silly little spindly spark rather than the thick fat spark I normally get.
Time to rework the ign system as well I reckon
The loss of metal around the liner at its deepest point is about 2.5mm. I'm hoping I can get away with filling this with ally or liquid metal and then hand smooth it. I'm not keen on using heat to flow some ally this close to the liner. Which is why I'll probably opt for the chemical metal option. I dont have time to pull the block and get it reworked. And I hope a comp gasket may take up the odd thou of eneven surface on the block. My thought is that the repair should not be under any undue heat or pressure on the outside of the liner.
Are the heads made of stronger ally?? Because there is no damage to the face of the head at all? Just a slight layer of ally spatter??
I may of course be completely wrong. But I'll have a go anyway.
If it all goes badly wrong, I'll have a year or so to rebuild and maybe transplant the running gear into the next project car. A rear wheel drive 4.6 V8 MG ZR. Or maybe the MK3 Escort 2 door shell we have laying around??
If anyone is sure that having this area filled with low temp ally filler or even having it tigged is ok I'll do that instead.
Advice please guys...
Pel
