I have had somthing like this happen before and it sounded very bad! turned out the head gasket had gone home and the gass was getting out and struming on the tin inlet gasket sounded like a big end gone.DEVONMAN wrote:It would be a good idea to compare the compression on No2 with the rest.ppyvabw wrote:I don't think the tapping is heavy enough to be a bearing. And it's not coming from the bottom.
I aint stripping it, I will leave it until it goes bang and get my 3.9 built and put in.
This will at least help to rule out some of the possible causes of the noise.
As r2d2hp suggested, a piece of hose in your ear will help to pinpoint the area.
Regards Denis
Have you done a compresion test?
