Oil cooler outlet/inlet (Rover V8)
"M18 as I said at the beginning (for the interim covers), preferred solution is an M18-NPT adapter so you can either plug or use for temp/pressure senders." is a load of old tosh, so don't take any notice of it! - it is M20, but the use of NPT adapters is still valid
All the serp TVRs (all interim) came as standard with the side one blocked and the bottom one with the pressure sender. I think I know of a couple of owners with blanking plugs left over after adding temp sender adapters if you get stuck. TBH its probably cheaper to get a suitable M18 plug from a local hydraulics place though.
Grovel! Grovel! Grovel!
It is definitely M20x1.5, ignore everything I said unless you are looking for the adapter to plug / sensor the stepper motor. I must pay more attention to crossing out and underlining (multiple choice was never my forte).
I shall humbly edit all the posts above just to make sure their is no confusion as a penance;)
ETA: In fairness I did answer the OP originally...
To: AdamR
Posted: Mon Mar 23, 2009 9:17 pm
Subject: Re: Oil cooler outlet/inlet (Rover V8)
Both oil cooler ports on the timing cover are M20 x 1.5 pitch definitely Wink
I stuck one of my stamped sample bolts in a cover I have off at the moment.
To: AdamR
- topcatcustom
- topcatcustom
