burgesstuning wrote:Hi Dave
I have been pondering the criticism of my flow bench since you told me about it yesterday, always interesting when someone states 'categorically' that something is wrong and has a design flaw!
I developed my flow bench to measure air flow in a repeatable manner so accuracy of readings and end results were most important, I have never stated the figures are accurate as measured by a 'micrometer' in fact if we get into fractal maths how can we measure how long a piece of string is? My flow bench compares two pressure drops one of which is across an orifice of known size and approx 59.6% efficiency, with measurements of the pressure drops,temp,humidity and atmospheric pressure we can calculate airflow. Now my bench does not need to be calibrated on a daily basis as my maths calculates the effects of atmospheric changes. We are dealing with a process where everything apart from entropy changes, hence isentropic process. An item that flows x cfm on my bench at 25" H2O will always flow X cfm @25". I do not set bench to 25" H2O I calculate what flow would be at 25" H2O.
Now along comes someone that gets different figures from mine, their assumption is that my bench is wrong and to 'prove' it they say I am measuring pressure drop accross the head at a point of recovery. If you stop and think about it...if I increase the pressure drop accross the head my final figure will be alower one. I put the following figures in...T =15, Atmospheric pressure 1013.25mb, vapour pressure 1400n/m2, humidity T 0.80, valve 41. For first calculation assume pressure drop across head 1400mm H20 and pressure drop across orifice is 350 mm. Flow at 25" H2O is 46.06 cfm. Now increase pressure drop across head (cos the 'experts say this is the case because I have tapped it wrong and the drop across the head should be higher) to 1500 mm H2O , keep all other figures same and you get a new cfm of 44.24 which is lower still. It shows that the 'experts' do not follow how my bench works and maybe, just maybe, they are wanting to find fault with my bench per se!
As I said I set out to build a bench to give excellent repeatability. The numbers are irrelevant as each flow bench operator must learn their art from their own figures. The mods I outline in my book work, they are not bullshit guessed at but produce real bhp gains. The heads can always be improved more but we are into diminishing returns.
I know I have rambled on but I feel I wanted to counter the criticism of my bench. Now maybe my bench does read 20% low, it doesn't matter. But if the figures are low it isn't due to a pressure recovery in my bench, that would make my figures even lower and that would never do would it?
Over the years we have flow tested a lot of heads that have been on different flow benches. All the figures have been different on my bench (apart from the 'calibration' holes we tried in conjunction with the Harry Weslake flow bench). Most of the heads had been on different superflow benches and the figures were different from different benches. I am not bothered what the figures actually are, as long as you supply your customer with a product that works that is what is required. I have seen heads flowing (according to the certificate...)way more than a standard head only flow about the same as a standard head on our bench, did the person who originally rework the head sell flow figures or performance gains?
ramble ramble
Peter
I think you may be confusing Peter with Paul Goodenoughsidecar wrote: PS I have a set of V8 Dev heads, I believe that you do their heads?
