V8 FILTERS
PLEASE contact me before posting in here,
As i need to make sure what is being offered will benefit the members of the forum,
NorthernBloke
Post by NorthernBloke »
I'm going to be putting the Mk1 back on the road shortly and one of the pre reqs is, of course, oil and filter change and after reading through this thread, and especially the last page with Andrew disection, I would like to give your filter a go :)
Have you sussed out the paypal link yet as that would be easiest.
Andy
slice
Post by slice »
.[/quote]
Hello Andy
thanks for your interest in my filters!
the Paypal arrangement cocked up somewhere when i was setting it up - seems as though its gone wrong at my bank.
I'm going to the bank tomorrow morning to try and resolve the issue.
will be back to you tomorrow nite
thanks again :)
dave
SLICE
andyv8van
Post by andyv8van »
Will also order one of your filters when you get the Paypal sorted.
Ill be Ready for the show season then.......... :D
regards
Andy
3.9 V8 Mini Van....THE BEAST
slice
Post by slice »
Hi Andy, Andy
i dont know much bout bank accounts 'n stuff...seems it was me that cocked things up!! - but, must say the guys at Abbey were very helpful!
Can't fix the problem straight away though - it might take up to a week to sort out.
will let you know the moment its sorted and paypal is working
thanks again guys for your interest
cheers dave
SLICE
NorthernBloke
No bother Dave, I'll keep an eye on the thread 8)
Andy
andyv8van
Post by andyv8van »
NorthernBloke wrote:No bother Dave, I'll keep an eye on the thread 8)
me too
Andy
slice
FINALLY.....
Post by slice »
Hello again Andy, Andy
the account is finally sorted and my site has been updated to accept paypal.
Plent of filters in stock for whenever you're ready
thanks
dave :D
SLICE
NorthernBloke
Nice one Dave, just ordered mine - gone back up to £20 + p&p, is that correct?
Andy
andyv8van
Post by andyv8van »
have put an order in for mine
regards
Andy
slice
ONE SIZE FITS ALL
Post by slice »
Been busy with an investigation - finding out what other V8's my filter fits.
pleased to announce that it fits ALL Ford V8's and ALL Chrysler V8's.
Also discovered that 99% of the "remote mounted" filter heads also have the same threads (3/4 - 16 UNF)
Its a far more popular thread than i imagined.
So... if you're interested in upgrading pls send me a msg with your existing filter number and i will check it out for you
thanks
dave
SLICE
i would if you did a shorter filter :lol:
Muscle-Manta
Post by Muscle-Manta »
Dave, I have ordered one of your filters. How many miles do you recommend between filter changes? Would every other oil change @ 5000 mile intervals be sufficient?
slice
filter change frequency
Post by slice »
hello Paul thanks for the order!
how many miles do you generally travel per month and is it good steady runs or stop start heavy traffic?
the reason i ask is because if you are on long runs then less carbon is being generated and finding its way into your engine oil.
My filter does remove this carbon (as well as all the harmful solid contamination) from oil circulation but this will naturally reduce the service life of the filter to a degree.
as an example i travel some 1500 miles per month on good runs with very little idling.
With the present filter i have done 15,000 miles (same oil & same filter) and the oil is still spotless! (i test it regularly to check that there isl no solid contamination in circulation) however i have decided i will change it next weekend because i begin to be concerned about natural depletion of the oil anti-wear and anti-oxidation additives.
so... it seems you don't travel long distances then a filter change at every other oil change sounds a good option.
if you have any other questions then dont hesitate to shout
thanks
dave
SLICE
Muscle-Manta
Hi Dave, As the car is only used for fun I plan to avoid traffic and long periods of idling if possible.
I don't comute in the car and cover no more than 5000 miles a year.
Paul.
slice
Post by slice »
hi Paul,
yeah i think that the 5000 mile annual filter change would work well for you then.
one thing you will notice once the filter is installed is that the oil won't go black as it normally does - it will stay much clearer...and only become an amber brown by the time you come to change it in a years time.
this is simply due to the higher efficiency glassfibre media
the filter will be on its way to you tuesday morning
thanks again
dave
SLICE
Return to “Discounts Offered To Forum Members”
