All noise measurements were made with the same meter using the "standard" trackday test of 45 degrees, 0.5m and 4000 RPM.
With the STANDARD silencer (but an interesting engine) with twin 2" compression bent tubes, it made 113.5 dBA
With the new Edelbrock SRT silencer and a much smoother flowing mandrell bent twin 2.5" tube system it is now a more reasonable 106.5dBA
However, the trackday noise limit I need to achieve is 105dB, but I would prefer something much closer to 98dBA so I can use it at Goodwood.
Short of welding plates across the back, are there any ideas?
Here's a couple of old pics. One with the old exhaust fitted, showing how little space there is to work with, and one with the tacked together new system.
Thanks![/img]
