Distributor wiring?
AndyS2
Distributor wiring?
Post by AndyS2 »
I've just finished putting a new V8 in my Range Rover and I've got 1 wire left that I can't remember where it conected to. It's a single green wire coming from the amplifier on the side of the distributor and it has a large eyelet on end. Anybody help me out, I'm dying to fire it up!!
Andy :D
jrv8
Post by jrv8 »
Which terminal is it connected to on the amp ?
Jim
AndyS2
Post by AndyS2 »
On closer inspection it actually goes to a spade terminal just above the amp, here's a pic:-
Any ideas??
1991 Range Rover Classic
V8 Developments 4.2 short motor from TVR 420SEAC. Steve Lund big valve heads, LE1 Camshaft. 1 straight through silencer, Nice!!
softdash3.9
Post by softdash3.9 »
Hi Andy,
Nice to see you've got it in :wink: the wire isn't for the oil pressure gauge to the left of the front cover or temp sensor?
Regards
Royston
jrv8
Post by jrv8 »
Hi Andy,
That terminal is for an earth connection, (not always used) ,but the wire colour is normally black.
Jim
AndyS2
Post by AndyS2 »
Royston,
I thought that when I first saw it as it's the same type of connector but the oil pressure sender wire is built into the loom, this is a single wire.
I'll try earthing it and seeing what happens. Thanks for suggestions.
Andy
