Custom Propshaft
- topcatcustom
Custom Propshaft
Well, going to need a prop to connect my LT77 to 7.5" Cossy LSD, as there is a flange both ends I'm guessing I need a 2 piece as there is no forgiving spline to slip in to.
I dont have anything for it yet but plan to make it myself then get it balanced, the sierra ones dont have sliders so what is best to use- I'm assuming the LT77 has a pretty standard flange size so what are my options for donors?
TC
- topcatcustom
Yes, you're right the earlier TVR's used LT77 and ford diffs.
You might try speaking to a couple of custom prop manufactures? They may sell you the ends to weld your self.
Had one made recently, to my design and thought it was a very reasonable cost. (Didn't fancy welding it myself as I didn't want to test the strength of my hip whilst launching of the line
- Knows His Stuff
Early TR7's had a 4 speed box and used a Marina style rear axle which presumably had an Austin background. Can't see Ford being involved with BL.
5 speed TR7's used the lt77 box and an axle similar to the rovers but narrower, with a different pcd and smaller diameter shafts. Diffs are swoppable though. Mines a 2.84
- topcatcustom
Have a chat with Bailey Morris. They made my Van one.
I took in a scrap SD1 prop (with CV at both ends) to provide the donor CV joint, but they had some brand new ones in stock!
They know their onions.
http://www.baileymorris.co.uk/
- topcatcustom
- topcatcustom
