Cheers KevinCastleMGBV8 wrote:Richard,
The PCV system should have one valve cover with a filter, not to the carb filter and the other cover should have in this order a flame trap then pcv valve then connected to the centre port on the carb, the way you have it you will not get fresh air venting the crankcase and no effective pull through to the base of the carb.
Great car by the way, I'm quite nostalgic as I had a Mexico Brown with beige leather 3500S back in 1973 and absolutely loved it, all it needed was a better 5sp g/box and the engine modded for a bit more power and revability, I was even looking on e-bay last night but nothing nearly as nice as yours.
What sort of money for one similar condition to your car even with an original engine and box.
Kevin
as the PCV valve is in the rocker cover. The only way it can be done is PCV valve, flame trap, then PCV port.flame trap then pcv valve then connected to the centre port on the carb,
Hello Kevin,Do you know if the ZF4HP22 autobox will fit the P6?
Well that didn't take longRichard P6 wrote:I have done all of the small things on Sparky, next job is really going to be a complete strip down, derust (not much of that anyway) and a respray.
