[quote="topcatproduction"]I believe I have actually found a man who is a book on all things V8!
Sorry Mike I slightly missread your first post, so for most power you
dont want a full system, and the most important thing is really just making sure all the primaries are equal lengths, then into short secondaries, followed by a nice megaphone?!
Not quite correct
You wat equal length headers if you are looking for max power at X rpm with the length varied depending on what revs you need to use
Some say to get a better spread of power you need to use headers of variable lengths and then you can also pair them eg 1 and 4 vs 2 and 3 and equalise total volume on these etc.
Biggest thing in getting more power is getting a smooth tranfer at the connections be it 2 into1 or 4 into 1 etc,
Oh yes and if you are making your own pipes and need to ceck lengths simple way is blank one end and check volume of water that will fill each header. Oh and another old trick to stop pipe "crushing" when you bend it fill it with water and freeze it - the ice will crack but still hold the circular tube shape
