Rover V8 Engine Numbers Updated:
Engine Size
I took the sellers word on it being a 3.9.I live in Northern Ireland and bought the engine in England so I never saw it until it arrived.Ah well looks like it will be used anyway after reading about the 3.9 cracking problems.I have a good engine builder about 5 miles away called JRV8's hopefully he'll keep me right.
hi i have been trying to get hold off eric for the last couple of days for a letter .but no one answering the phoneIan Anderson wrote:There is a contact in Landrover who, for a small fee towards the landrover club will issue a letter that is acceptable to the SVA men in coats
(It worked for me in 2006)
Name
Eric Pagan
Traceability Systems
Land Rover
Lode Lane
Solihull
B92 8NW
0121 700 4524
do you know how much letter costs and who do you make cheque payable to
regards pete
Muscle-Manta
I have a 4.6 with a strange compression ratio stamped on it, the engine came from a scrap yard with Range Rover injection on it but have no other history, it is stamped:
CR9.37:1
S46D45366A
From the list this is supposedly a Morgan engine?
Could it have been a special build?
Any info would be great,
CR9.37:1
S46D45366A
Sometimes i ask myself, why do i bother? Then she starts up and everything becomes clear.....
- Malcolm Tent
any ideas peeps
just bought a V8 for recon,,,engine number 48600495A Marcos? all the best and look forward to any responses...Shaun
Keep the shiny side up and the dirty side down
Thanks katanaman ..had a look on the various listings and had no luck with the 5A part and only saw the Morgans listed as 3A,,,Was advertised as a Rovercraft engine requiring a rebuild due to engine being a little tired...have removed the heads and so far its all mint
Muscle-Manta
I have copied below an email I sent to Mitchell Cotts giving the engine number of a 4.6 short engine I have bought from Rob at V8 Devlopments.
I am very happy with the deal Rob gave me £1,000 plus my old 3.9 short motor. The new short engine has been fitted with 4.0 pistons which brings the compression up on the 4.6 - I am aiming for 10 to1. It has also been balanced.
Enquiry
Sent: 08 December 2009 08:22:23
To: Ian Briggs
Cc: Andy Cook (andy.cook@gearboxes.com)
“enquiry: Hello, I am hoping you would be able to help with some information on a Rover V8 engine block with the following number XM46D306B24. I have been told the "XM" denotes the engine was manufactured/remanufactured or assemblied by Mitchell Cotts. Would you be able to confirm this? Does the number in some way denote the date of manufacture or re-manufacture.
I have seen Rover V8 blocks advertised for sale as being "Costcast" blocks, is the above engine a "Costcast" block?
I would be very grateful if you would get back to me with any information you may have on the above engine number.
Hi Paul,
I can confirm that the XM is our remanufacturing code. The 46D3 is the engine type, 06 is the year it was built, B is the month it was built so in this case it was February & 24 is the consecutive build number
This is not a coscast block as we didn’t start production with these blocks until July 2007
Hope this helps.
Kind Regards
Ian Briggs
Quality & Engineering Director
MCT ReMan Ltd
Winterstoke Road
Weston super Mare
BS24 9AT, England
tel: +44 (0) 1934 428016
mob +44 (0) 7813 677716
fax: +44 (0) 1934 414768
email: ian.briggs@gearboxes.com
Enquiry
To: Ian Briggs
Hi Paul,
Hope this helps.
Kind Regards
Ian Briggs
MCT ReMan Ltd
Winterstoke Road
Weston super Mare
BS24 9AT, England
Muscle-Manta
Further to the above I wrote again to Ian Briggs at Mitchell Cotts and asked if they had done anything to prevent the block cracking problems Land Rover had with these engines. His reply and the attached document are below.
Paul.
Hi Paul,
Obviously when we took over the build program from Land Rover in 2005 we worked with their engineers to understand the problems that they had themselves during production & the thin wall condition was tabled. To ensure conformity our machinist at the time put in a 100% ultrasonic gauge check that enabled them to measure the wall thickness between the water jacket & the cylinder bore. Dependant on this size they established what variant of block could be used to build either a 4.0L or 4.6L engine & obviously they scrapped any block that was too thin in the area of concern. I have attached a section of the company’s process instructions that relate to the test they carried out for your interest. I hope this clarifies what you need to know & also provides you with the comfort that the engine supplied by us will not exhibit the “known” Land Rover failure.
Kind Regards
[/img][/url]
Paul.
Hi Paul,
Kind Regards
[/img][/url]
