Different engines
Re: Different engines
I believe that there is not 100cc difference, they are in fact the same displacement!V8 Rail wrote:Apart from a 100cc what are the differences between 3.9& 4.0 litre land rover V8
The 4.0 has bigger main bearing journals, it might be cross bolted as well. (not sure on the cross bolts)
As already said, they are exactly the same bore & stroke.
The 3.9 is 'old style', i.e. distributor, small mains & big ends
The 4.0 is the later cross-bolt style with no distributor.
There are some factory engines with a combination of the above....
As originally built by Land Rover for fitment into Discovery or Range Rover, the 4.0 was not fitted with a distributor.
The engine that you have a chance to purchase will thus be running with a different timing cover, which is not a problem.
The flywheel off your P5B will fit straight on, no problem at all.
Ron.
Ron.
4.6 Rover 3500 P6B
- topcatcustom
3.9 is your cheapest option as it will have a dissy already, if you go down the 4.0 route you will have to find an interim front cover which aren't cheap or particularly easy to find, and of course a dissy to go with it, and all the serp belts and pulleys etc, you cant use V belts on a 4.0 or 4.6 as the water pump spins backwards with the serp belt arrangement.
Power and reliability wise, if you get a good 4.0 block it will technically handle more power than the 3.9 due to the X bolts, however there is unfortunately a much higher chance you will have problems with liners slipping with a 4.0. A 3.9 with ARP's will easily handle over 200bhp before you have problems with the bottom end so unless you are going down the forced induction or nitrous route, X bolts are not a necessity.
TC
TC
- topcatcustom
10:1 compressiontopcatproduction wrote:Your 3.5 must be a good spec Zander! What is it?
rhoads lifters
real steal typhoon cam - i think... (the one they got 250hp out of on a 3.5)
stage 3 v8 developments heads
quad downdraught dell'ortos 34mm on JE manifolds (IR)
standard crank and conrodss (fully polished)
high volume oil pump
polished lifter galley
billet rocker shaft outposts
well thats the spec.... havent bought the heads or lifters yet though as am short on cash.... its still in the block machining stage waiting for cash!
Zander
Haha yeah! Another company (cant remember the name) also say they have got 265 out of a 3.5 with only a tiny bit more duration, and can provide a dyno graph to prove it. havent asked yet and cant remember the company to hand.sidecar wrote:Hmm...so they say!crayefish wrote: real steal typhoon cam - i think... (the one they got 250hp out of on a 3.5)
Either way, my engine is better spec so should produce at least 240... and the dell'ortos should produce some good torque!
Zander
- topcatcustom
I am hoping it will be a one off thing and then they will stay tuned! Fat chance of that happening though...
The main thing I am worried about is the break-in procedure for the cam... it has to be started and then rev strait to 2000rpm for 20mins. If the carbs arent set up right (though the seller says they have been sincronised) then it might not get to or stay at 2000rpm...
Zander
