anyone know 3.9 rv8 weight????
nickh
Post by nickh »
hi everyone im new to this forum and hoping some of you peeps can help need to know the weight of a range rover 3.9 v8???
cheers in advance nick :D
softdash3.9
Post by softdash3.9 »
Complete V8 @ 230kgs, source RPI website :wink:
Regards
Royston
nickh
Post by nickh »
nice one cheers mate :D :D
You sure that's not lbs rather than kgs? 1/4 ton seems rather a lot!
smokeonthewater
Post by smokeonthewater »
Yeah I think 230kg sounds abit heavy :!:
I would say it was just a good 2 man lift as me and my brother lifted one into/out of a landrover, then carried it down my garden to the shead by the header pipes :wink:
230lbs I think is about 104kg which sounds more like it to me
P.s It was heavy though :lol:
jrv8
Post by jrv8 »
I've a book of V8 engine data & weights, and it's showing the Buick 215 (RV8) engine as weighing in at 318 lbs .
This doesn't seem too far away , as already stated, it's a heavy two man lift.
Jim
smokeonthewater
I looked on the wikipedia site & they say its about 170kg, and the V8church website say about 320lb which is about 145kg :? :? :? :? But they also put a little note about the weight being- "Approx, will vary depending upon nature of ancillaries fitted. "
softdash3.9
See below:-
http://www.rpiv8.com/engine-4.htm
Haven't weighed one myself, all up weight inc ancillaries
Regards
Royston
katanaman
Post by katanaman »
Could be that weight with every conceivable ancillary on the engine which you wouldn't be running anyway. Even then I think RPI have it wrong. I would say in normal trim its around the 145-150KG. A 302 is 210-220KG with starter carb and alternator. There will always be variations in engine weight depending what you have bolted onto the engine.
adamnreeves
Post by adamnreeves »
The short block I now weighs 80Kgs. I took the PRI 230Kgs figure to include everything and I mean everything, transmission and all.
jsstevo1
Post by jsstevo1 »
Found the below :-
Width = 26'
Length = 28'
Height = 27'
Weight = 320 lbs
Note: Approx, will vary depending upon nature of ancillaries fitted.
Cheers!
Paul Dryhurst
Post by Paul Dryhurst »
Ring this No: 01926 646974 ask for John (Weights Department Land Rover). He will tell you what you want to know if you give him the spec. Man ,Auto, Air con, with oil , pas etc.
Regards
Paul (mention my name.
P Dryhurst
