replaced the worn oil pump gears in my 3.5RV8, question is do i just put it back togetgher and prime it or is there a way of doing it?
cheers
garry
oil pump advice
Belt and braces way is to pack the gears with vaseline and bolt the cover back on. Fill the new filter with oil and put the rest in the engine. Prime with a drill at around 2000 rpm.
Works everytime for me
Hi,the vaseline provides a point of suction for the pump which in turn draws the oil through the galleries and into the pump and then around the engine.
You do,nt have to drain the oil either after the pump is primed because the vas just breaks down to nothing in the sump.
Hope this answers your question.
