Nightmare, nightmare? it's all good fun!bigaldart wrote:So glad we have MFI and Methanol on the dragster. Carbs were a nightmare LOL
John, email with attachment sent.
I've just been out for a spin after drilling a 12mm hole in each counter weight. The results seem very good, the motor has more poke off the line and through the rev range. The holes are just slightly too large because if I stamp the throttle down VERY quickly when in top gear at about 2000 RPM the motor dies for a fraction of second, the mixture goes to 16:1 but then it picks up again. (Mind you the acclerator pump is on a very lean setting as the pump arm has been extended).
I'm going to fill the holes with solder then drill them out to 10mm.
I don't think that this mod would work too well on a smaller RV8. (Or you would have to go carefully making the holes slighlty bigger each time with testing in between).
I can explain where I drilled them if anybody is interested.
I weighted the assembly before I did any drilling "just in case" (I now have a small bag of bolts that is the same weight as the standard flapper valve!)
Pete
