Haltech
plank22
Haltech
Post by plank22 »
Has anyone used haltech managment on a rover 3.9 v8? If so opinions please................ta!
RoverP6B
Post by RoverP6B »
Hello Plank,
Here is a link to a discussion on this topic at the Australian Land Rover Owner's forum.
http://www.aulro.com/afvb/technical-cha ... rchip.html
You might find it helpful.
Ron.
P.S : I was not one of the contributors.
4.6 Rover 3500 P6B
Ive never used them on a Rover, but Haltech do make good ecu's
Which model were you thinking of using ?
http://forums.haltech.com/index.php
plank22
Post by plank22 »
cheers guys rele helpful, I have one with the loom all ready its a E6X. Its going in a land rover so all I want is a base map and perhaps a "live tune" as all I want is reliability rather than performance.
Ask over on the Haltech forum
Base map will be tricky, unless there is someone out there using the exact same setup, with same triggers and sensors etc
plank22
Post by plank22 »
was hoping for one just to get it running so as i can get it over to the tuning man to tweak it a little. This sound possible?
P.S just saw the vid of your garanny at pod, holy sh*t!!!
Anything is possible.
But in order for a guess map to get you started, you would need to gie very specific details about your setup.....
And TBH, if you knew enough of these details, you could work through and get it started yourself anyway.
Just follow through the instructions. It wont be that bad.
plank22
Post by plank22 »
ok its just I dont have a clue for mapping and know of plenty of people who think they do and what they have done could not have been more wrong! So kinda been scared off......
kokkolanpoika
Post by kokkolanpoika »
i have got haltech F10 with my ex 4,6 stage 3 engine.. and now it is my 5,2l unit..
I can give them to you, but not sure how, because i live in Finland.. And i think you need old computer witch has got "dos program" to read those maps? not sure, but i think?
Timo
minorv8
Post by minorv8 »
Timo,
I had no problems reading your maps, (my laptop has XP). However, I think I need to read the values manually from each map since the file format was not recognised by E6X. Then the values need to be inpit manually to E6X files. Some work yes but would give something as a start.
Plank22, F10 is fuel only and naturally does not have ignition maps. You need to source them somewhere. Haltech ECU does have a library of ignition maps that will get you started.
I have bought a Haltech E6X and plan to have it fitted in the wintertime. Exact components are still open but I am using Haltech supplied sensors. I have two sets of BMW Coopes S injectors that should be plenty enough for Rover. Sadly they are of shorter design so the rail needs modifying. Or then I just need to buy another set of injectors with correct dimensions.
plank22
Post by plank22 »
ok great thanks, any feedback at the mo it good as im kinda limited in info!
