Dual Knock Sensors
Dual Knock Sensors
not sure if any of the MS guys can help.
have mailed a few vems guys on the vems forum but had no reply.
im looking at running dual knock sensors and wonder if there is a certain way they will need wiring in?
i gather they dont both connect to the same pins on the ecu.
Found this
http://www.vems.hu/wiki/index.php?page= ... FUserGuide
Bottom of the page Vems 3.3 pin outs - does that help
im going to to be safe mate, as nitrous can be funny stuff
yes mate thats good ta,
thats the latest pin out which i dont have (do now)
also i have been told to earth the sensor shileding at the ecu end,
but there it says to the block,
so i need to look into this also now,
next bit comes trying to set the ignition side and knock side up on the ecu
cheers Dave,
im wiring the extra wiring to the ecu plugs (ec18 and ec36) this weekend for the knocks and crank trigger,
Dave have you the old layout with the tach output listed?
as i cant find any reference on the posted page on the vems site on wiring in a stock tach to the vems,
i did have it writen down but cant find it,
edit:
ah i see channel 4 (pin3)
is a common one to use on the p259 chip.
will i need a pull up to run my rev counter? (stock rover sd1 counter)
and whats the divide for in the mt settings?
sorry i know its not knock related but its along the same lines lol.
edit:
Your tacho might not work with VEMS (or any other ECU) without a converter box. IIRC the SD1 tacho took its signal from the coil -ve, so is expecting 400+ volts of signal. VEMS will provide +12 with a pullup which may not work without the converter.
It's OK to use the P259. I use a channel for tacho driving on mine.
The divider was 8 for my tacho, but it died shortly afterwards (no damping in the coil) so I took it out to fix. Needless to say I didn't finish!
oh bugger so no rev counter then
what about the autometer rev counter i have?
will that need a converter box to?
starting to wish i left the dizzy in now
without any add ons?
straight off the ecu?
- topcatcustom
i know how they wire up mate,
but dont forget im not using a dizzy now,
its crank trigger and coil packs so the ecu needs to trigger the rev counter now.
