Struggling really badly with this P6 at the moment. Firstly the fuel tank was filled with crud which promptly got sucked up and jammed everything solid, and now this...
Previously it would run and drive fine with a good bit of power and would easily light up the tires, and run through the rev range nicely.
At that point the condensor died - and it would run intermittently. Now I have replaced that, the car will (just) start and run - but it is very down on power and won't rev cleanly or freely and sounds odd too. If you can get it over 3000rpm it becomes very unhappy and will backfire when coming off the throttle. I have a very unenthusiastic looking orange spark, even when taken right off the coil.
It idles OK at the moment but that's about it...
I have replaced all the ignition consumables (NGK plugs, Champion leads, new condensor, points, cap, rotor, LT lead) and have a new coil on order - but have tried two other spare coils. I set the points gap to the 0.015in as spec'd from the factory but have taken that no further.
I did take the carbs off and apart but have sync'd the butterflies, reset the needles and floats and that seems OK (at the time one bank was very rich, the other lean - so felt obliged to) - at least, it should run OK. I put a pair of new needles in as well as the old two were mismatched (!).
I have looked at the dizzy and well, barring it all potentially being set up wrong, the little copper earth lead from the points to ground looks very frail and tatty - could that cause it?
The rev counter seems fairly steady but does occasionally flit up and down a few hundred RPM, out of time with the engine.
So, do I just need a good tune up or is there something else amiss here? Getting very frustrated, and tired, of this as I got screwed on the insurance so it is my daily (non) driver.....
Thanks for any guidance here
