Plenum queries...
need4speed
Plenum queries...
Post by need4speed »
Will my hotwire 3.9 plenum be up to the task of feeding my rebuilt/modified 4.6, or would it be beneficial for me to bore it out.. Bare in mind that this is for a defender 110 not a light sports-car..
need4speed
Come on guys. Surely its an easy one for guys of your calibre...
Re: Plenum queries...
Post by CastleMGBV8 »
[quote="need4speed"]Will my hotwire 3.9 plenum be up to the task of feeding my rebuilt/modified 4.6, or would it be beneficial for me to bore it out.. Bare in mind that this is for a defender 110 not a light sports-car..[/quot
Presumably you have modified the engine to optimise torque in which case the 3.9 plenum should be fine for your purposes.
need4speed
Thanks for replying Kevin. Yes my engine is currently using standard later-casting heads, skimmed to up the compression a little, and using a real-steel stump-puller cam. I'll also be using MS and EDIS.
Phil
Big plenum is required for high revving large capacity engine - on a 4x4 its less of an issue, as you are maximising for torque in the mid range typically.
need4speed
Thanks guys. Looks like i can use the one i have after all. :D
Given that you are running megasquirt, all you need to do is compare your MAP pressure at wide open throttle @ max RPM with the pressure you record with the engine switched off - they should be close to one another ideally (~97kpa) - otherwise known as the barometric reading on MS.
