RV8 in my Stag - need to modify the carbs
russ spake
Hi, anyone know where I can get the pots on my SUs modified so that they sit under a standard Stag bonnet. I'm getting the boby work restored and the bonnet which has had a bulge inserted badly is shot, thanks.
Russ
Russ
- topcatcustom
I've seen strombergs fitted to clear the bonnet on Stags with the RV8, but I have also seen the mod to the SU's which IIRC involved taking the little chimney off the top, and than machining a threaded hole into then what becomes a flat topped dashpot, this being threaded to take the larger SD1 dampers which have to be shortened accordingly.
Mind you it was a good while ago that I saw them.
russ spake
- topcatcustom
There isn't a chance you mistook a HIF for a modified HS carb? Both are SU's and the HIF's generally look stumpier...
p.s. it can't be hard to put the dashpot in a lathe and part some of the neck off, then just re-tap it! Maybe the engineering shops you have asked got the wrong idea- it sounds like a half hour job, though maybe they are worried about being responsible if they don't work properly when they give them back to you!
If you research it and find you dont actually need the length or travel inside the dashpot, it shouldn't be hard at all.
Hello Russ,
This gent may have the answer. He is selling his Stag fitted with an RV8, and the SU carbs have been modified.
http://www.carandclassic.co.uk/car/C53088/
May well be worth a phone call!
Do lets know how you get on.
Ron.
Ron.
4.6 Rover 3500 P6B
russ spake
JC. wrote:You could bin the SU's and fit a webber 4 barrel on an offenhauser 360 inlet manifold. That is a much lower setup and would give you the clearance you need.
They do tend to be thirsty compared with SU's I find
russ spake
Thanks for the advice - fortunately my Stag already has a two bar, just need to modify the heating oil tank in the garden and fit it with a set of wheels to expand the fuel tank capacity!
Maybe I'll try and get an offy/webber set instead, though I don't really want to pay £500 for a new set, anyone where there's a good second option?
- topcatcustom
russ spake
-JC.
