MY LT77 DOES NOT HAVE A SERIAL NUMBER - HELP
devilhunter69
Post by devilhunter69 »
Last edited by devilhunter69 on Fri Jun 05, 2015 10:50 pm, edited 2 times in total.
Darkspeed
Post by Darkspeed »
Mine has the details stamped on the flat section on the left next to the alloy and looks like yours may have something there under the crud
Andrew
4.5L V8 Ginetta G27
devilhunter69
I have found the serial number.
It is on the bottom but at the front (just on the flat above 26 of the photo date stamp.
The number is I think
14ACL11491B
What the hell is it as I cant find anything that starts with 14A.
bodger
Post by bodger »
that could either be a sherpa/ldv200 or a TR7 box or even a 2ltr P6 , you will never know until you took it apart they all look the same outside
may sound like a silly question but how many gears has it got / ie: how many can you select ?
devilhunter69
bodger wrote:that could either be a sherpa/ldv200 or a TR7 box or even a 2ltr P6 , you will never know until you took it apart they all look the same outside
I have not got a gearstick so I really have no idea to be honest.
I have never seen a 4 speed LT77 though - they must be rare ?
bodger
Post by bodger »
you should be able to shove the selector back and forth with a screwdriver to see how many gears you have .. the rover 2000 p6 had a 4 speed version , the trouble is all the cases look almost identical , the only differances are the drain and level holes are in differant places but even then there is no logic to it ..
bodger
Post by bodger »
it looks after having a rumage around , ignore the 41a part of the number and CL****** is a TR7 box
thats what i have on my V8 , the ratios are very similar to early SD1 boxes , but there are some bearing size differances .. if it's been sitting around for while it's worth opening it up and changeing seals / oil pump and gaskets they are not expensive and it's an easy box to recon i get all my bits from :
Royce Power Transmission Ltd
1-2 Perry Road
Shenfield Court
Harlow
CM18 7LR
Essex
Tel: 01279 421461
very fast next day delivery
harvey
Post by harvey »
The Rover P6 was never fitted with an LT77 box, the only Rover 2000 that had one was the Rover SD1 2000 with the "O" series engine.
bodger
Post by bodger »
opps got my p's wrong again ...lol
well the rover 2000 had a 4 speed box in some and is exactly the same cases as the 5 speed just with one less gear and differnat size bearings
mickjo
Gear box identification suffix B'
Post by mickjo »
Did you find out what the suffix B' means? Just got a 3.5 19A VDP unit but ends B'. Which has confused me. Any ideas?
Mickjo
