they are correct, on early heads there is a bolt hole missing on the upper outer edge (look at power steering pump bracket adaptor we made) where the nut is welded on the plate is where another bolt hole and lug on the head should be,
regarding perry nah doubtful mate, but you never know :wink:
i still have a lot to do, engine needs to be finished, then start work on the car, wire in the coil packs etc, fuel lines, reconfig the ecu to wasted spark,
get the fuel and ignition mapped then think about the nitrous, all before the v8 day, don't think so :cry:
well had a good day today,tried 2 alternator brackets,
ERR4514 fitted a treat, (3.9 serp discovery?)
and also the bracket i got from forum member matchmetisse (no part number on the casting) which sat the alternator even lower than the above bracket for even more height clearance,
had to change the stat housing as my o/e sd1 housing fouled the alternator, But this one the sensor also fouled the alternator but the top hose outlet is in the correct place.
I need this one here: (this was borrowed from an engine for fit up reference) this has no sensor hole drilled.
This is how close it is with the sensorless housing.
Crank sensor ring fitted:
bones
Post by bones »
dont worry about the height ,just fit a power scoop thingie, problem solved, looking good young sir :D rich
cheers Rich,
its nearly ready to go into the cappa's engine bay,
also got a set of ARP flywheel bolts now.
can't wait to hear this bitch run,
Tony
On that belt set up can you confirm what you have
Bottom pulley is crank
Then following the belt in a clockwise direction
Unknown pulley
Alternator
Water pump (reverse rotation to standard one)
Unknown Pulley
So is one of the unknown pulleys a power steering pump?
Is the other an addition ? / Dry sump??? pump
If the 2 unknown pulleys are idlers why? as they rob power?
Could you not run
Crank
Idler
Water pump
Alternator low and on right side as viewed?
It would give you more wrap around on alternator or is slip not a problem on serpentine belts?
Less bits - less to go wrong
bones
Post by bones »
so hows retro day looking for the capri,, your alot further ahead than i am. and you got altwernator bracket soughted :( rich
bottom pulley is crank,
next going clockwise from crank is belt tensioner,
then alternator, then water pump then up to power steering pump and back to crank
Retro is still iffy mate,
still need to sort fuel lines,
need a 1.4kw starter (solenoid under starter as per SD1) not to the side.
clutch conversion to sort out,
water hoses to sort out,
coil packs to fit and wire up,
crank sensor bracket to make and fit,
engine mounts to make,
gearbox mount to make,
new exhaust to mod and fit,
oil cooler pipes to sort,
oil cooler sandwich plate to sort (parrallel outlets)
map the fuel and ignition (need to try and sort an ignition map to try and start the engine yet)
thats just a few things to sort mate :-(
dnb
Post by dnb »
Don't worry about the initial ignition mapping. I have something that'll sort that out :)
Cheers dave,
will be sending you a message soon regarding initial set up of vems regarding the crank sensor etc. in relation to the cut out
Thanks to caprisport for sorting out the bolts (making them) etc and head work for the mounting bolts, (holes drilled and tapped)
the engine is not far off being ready for refit,
not done much on the engine this weekend,
lack of funds at present.
BUT hopefully have sorted the serp belt problem now,
and we may just have enough clearance for a range rover 1.4kw starter due to the small compact size it is, it looks like the solenoid mounted on the side may just clear.
Well the plenum was looking tired and the paint was starting to come off in places,
so its been stripped back to ally,
been etch primed and awaiting top coat, (pics to follow)
have new rubber seals and locking tabs to go on the shafts this time round also.
does anyone know of a exploded diagram of a twin plenum chamber?
well the paint came out better than i thought this time round,
new seals and lock tabs were fitted this time while the plenum is off the car,
Post by CastleMGBV8 »
Tony,
That is looking nice, is it black or gun metal grey difficult to tell from the pic.
Great progress and youv'e still got 4 1/2 months to the Forum Drag Day.
Keep up the good work.
