have just purchased a tvr 4ltr griff engine. The engine numbers correspond to a griff engine however is there an easy way to prove i have a compression ratio of 9.8 to 1 instead of the range rover 9.35 to 1.
Also the heads are stamped etc8622 i cant find any reference to these numbers.
Finaly is there any easy way to confirm what cam is fitted.
Thank you gents.
Shaun.
tvr 4ltr
- sax player
They arent p38 heads, they are 14 bolt, not 10.Rossco wrote:Disco 2 and P38 Range Rover heads.
Compression is set by the piston dish so without measuring them you can't tell.
As for cam again unless you can find a number then it could be anything.
Not saying that it's not a Griff engine but who told you it was a Griff engine and what proof did they supply?
As far as the history shows the cam hasn't been changed from standard TVR fitment.
And it is a Griff engine, I took it from MY GRIFF ! HTH
