Eatom M90 blower
andyv8van
Eatom M90 blower
Post by andyv8van »
hi
Best place to get Eaton M90 blower?
company in england sell them?
Andy
3.9 V8 Mini Van....THE BEAST
whats it for? there's a 112 in the for sale section.
andyv8van
Post by andyv8van »
Its going on my 3.9 rover
Andy
JP.
Post by JP. »
Then go for the 112............... :idea:
'73 Ford F250, 6.7ltr V8
Building a GT40 mk2
andyv8van
Post by andyv8van »
Andy
Rossco
Moderator Gold
Moderator Gold
Post by Rossco »
Andy
The only issue you'll have with the 112 is that it is very slightly too big in terms of low rpm flow for the 3.9
The M90 has to work harder but is better suited to the lower rpm range i.e. up to 2200rpm
but that 112 seems good value!
andyv8van
Post by andyv8van »
thanks,
i think any blower will be tight for room anyway.
will look at 112`s then, asked for more pics for the one on the forum
may be coming my way
will have to remove some of the castings to improve height restriction
Andy
Chedder
Post by Chedder »
andyv8van wrote:thanks,
Andy
Don't have to mount them in the V of the engine, the M90 lends itself to side mounting too, iIdid this last year as I did not want to alter the bonnet of my old TVR, doing it this way made fitting an intercooler much easier too.
Old TVR's never die....they just get faster!
Nice - Have you grafted the std RV8 throttle onto the end of the S/C?!
Whats required to make the 14cux understand the extra flow of the supercharger?
Chedder
Post by Chedder »
Well spotted, chopped the throttle body off the plenum and adapted it to fit the M90, turned the plenum through 180* to make an easier route for the intercooler induction pipes.
Not using a hotwire 14cux, as still on a flapper set up with a jag afm and an adjustable 4cu ecu.
Got around most of the problems by using a Vortech SFMU fuel regulator that can be adjusted in 3 ways to react to the boost pressure. works ok but maintaining a strong idle was a bit of an issue that took a while to get right, having finally sorted it 8-) I am just about to remove it all and fit an emerald ecu and coil packs so fully mapped fueling and ignition will hopefully put the minor niggles to bed.
Chedder
Supercharged V8 Mini sounds evil :twisted: !!!!!!
andyv8van
Post by andyv8van »
nice ,set up.
i think i will have more room that i first thought, the weber car is tall and also i have fitted a carb spacer.
thanks for the replies
Andy
andyv8van
Post by andyv8van »
hi chedder,
It sounds like running with a standard throttle body works...well with some problems set up problems, but i guess you expect it
i`m trying to get ideas to how i can fuel the engine when i go to the supercharger, i will put electronic ign set up first then go with the charger set up.
Andy
Return to “Forced Induction”
