more powerful alternator
i'm thinking of fitting a more powerful alternator , i have a 75amp one at the moment
but with engine battery / leisure battery / electric fans / spot lights and an invertor ... etc etc it could do with some more help on charging ..
i'm looking at maybe 100 amp or even 120 amp
what else do it need to change / do ??
thanks
keith
thanks
keith
thankyou Chris , i did think about fitting 2 i even bought a second one then couldn't work out where to put it ??
if fitting just the one how high would you go ??
there are loads on ebay ...100 120 or even 150 ..the 100amp vauxhall zafira looks possible or the astra 120amp is quite cheap too
- topcatcustom
- topcatcustom
I take it the split charge unit only cuts the supply to the aux battery? Only ask because the ones I have seen divert to the different batteries depending on condition. What your showing is basically a big relay. Also be careful if it is as it will drain the main battery if it is higher charge possibly resulting in a lot more than 100 amps flowing. Course if its an actual unit it will have flow protection built in so it isn't a problem. Might be an idea to put another relay or isolator on the main battery if it isn't. you can isolate it then with the added bonus of not flattening the main battery so the motor will always start.
basicly thats all it is yes , it's trigger by the alternator sense wire when the charge light go's out the relay closes then charges both batteries , the aux battery feeds a ZIG unit in the back of the van
what i was wondering if there any reason that starter runs to the battery / then the alternator has a seperate wire to the battery / then the spilt charge has another wire to the main battery from the relay ie:STD
i was wondering if it could be done like the picture to save running 3 seperate cable from onwe side of the engine to the other and just have the one cable
- topcatcustom
Why not use a rubber exhaust bobbin as a stud near the alternator and use it as a base to join wires instead of on the back of the alternator?
I have done this on my landy to move some of the wires away from the battery to clean it all up a bit and it works a treat!
Just drill a hole in the bulkhead and bolt on the bobbin, then use the other as a + stud. You can get a good connection on an 8mm thread as well.
