Range Rover 2 Door wrote:
I am intrigued though, by the battery voltage I am getting when it should be zero. If that leads to a definite line of inquiry, I could check it out and report back.
Thanks for now.
OK, I confess to not quite understanding what the manual is getting at, having re-read your quotation from it.
However, this is how it should be:
- With ignition off, both sides of the coil should measure 0V when measured between ground and the coil terminal. If you measure between the batt +ve terminal and either coil terminal, I would expect to get 12V.
- With the ignition on, but the engine not running, you should have +12V on both sides of the coil, when measured between ground and the coil terminal. If you really have +12V on one side, and 0V on the other, then the coil will get hot fairly quickly, which is wrong.
- With the engine running, the coil +ve should be +12V, and the coil -ve should be pulsing between 0V & 12V too rapidly for the voltmeter readout to respond, so you'll get a meaningless result, e.g. 19V!
If you decide to go the LEDs route, you'll need a handy technical mate to sort it out for you.
