I run a 91 Hilux pickup with a 3.5 V8 out of an 89 Range Rover .... bit of an old motor but works well .... I fitted a new Edelbrock inlet manifold and a new 4 barrel Holley carb ( vac secondaries) .... new Pop Brown headers and a set of handmade stainless 8-to-8 pipes ( 4 each side - Mad Max style)
Anyhow , ive run it all year up and down the country and not had a problem ...errr till now .... Suddenly wouldn't run properly underpower ... then would stall , then would be ok , now it'll start and tick over fine and rev up a bit... but hold it on a steady throttle and it backfires and then dies..
I've rechecked all the usual stuff and all seems well .... But I'll be going through it all again over winter
Now I've been told that Holly carbs can go way out of sync on the front and rear floats and cause these symtoms??? ( I never had a prob with this set up for 7 years in a Cobra !?!?) ... It sounds like ignition faults but feels like fuel starvation ( I run a new carter pump and it pump just fine )
Anyhow ....any sugesstions ??
I want to sort it out before I pull the motor , cos I'm gettting a new eng for Christmas ( I hope
it sounds fine http://uk.youtube.com/watch?v=wVHQsSaf0fM
