sidecar wrote:In answer to your question about CR, IMHO the only real way to work theoretical CR is by buretting the heads and the pistons at TDC. The head gasket can be calculated. The CR can then be worked out using a bit of maths.
A few months ago you posted about this engine not running at high revs, did you ever get that sorted out? I suggested that the problem might be due to detonation, did you ever get to the bottom of the issue?
The max PSI is affected by too many other factors to be a reliable method of working at the CR.
15 bar is about 217 PSI, from what I've read I think that is too high, especially considering your cam will have a longer than the standard duration so it should be lowering the PSI at low (i.e cranking) speed.
Like I said....AJMHO!
Pete
yeah got it all sorted.... the ignition amp was breaking down.... didnt find out untill it wouldnt start one day, and found i wasnt getting a spark...... changed itt for a complete MSD ignition... made hell of a lot of difference
it happened again not so long ago, but that turned out to be a knackered idle control valve... it completely came up the ghost, i also recon it way have been on its way out while the amp was failing, so had to problems....
when you said my cam has a longer duration, in what way do you mean???? if you mean overlap then you are wrong, my inlet opens 7 BTDC and exhaust closes 11 ATDC so ive only got 18 degrees overlap which i think is hardly any....... i chose this cam to get as much torque as possible and by having hardly any overlap, to help with compression
