Gems serp timing cover 'V' Interim 3.9 Serp timing cover
TVRleigh
Post by TVRleigh »
topcatproduction wrote:Do you have to worry about the condition of oil pumps in newer type front covers when buying?  There are a couple on ebay (& obviously I am looking for one) and need one to fit on serp engine and want to use dizzy too- can I get a 4.0 cam with dizzy drive?
The pumps I've taken apart seem to have very little wear. but can't answer how long they last. also I've not fitted my SPA digital oil pressure gauge to see what pressure im getting from my S/H one.
Your need a 3.9 Cam not a 4.0 as your need the dissy drive.
This gives you a lot more choices, as there are a lot less choices with the 4.0 cams DJE do custom ones for dissy-less engines. can't report on how it runs yet do to HT problems.
Current V8 car TVR 400SE 240 BHP
Current Project TVR Tasmin Race, with 3.9 running at 230 BHP
Currently building a 4.6 300 BHP Xbolted Engine for it. Solid Lifters and Group A rockers, Stange 4 heads, Pocketed piston, fully balanced.
topcatcustom
Post by topcatcustom »
Sorry that question wasnt because of mistrust but because I have seen the state of an old one that I took apart!!! Thanks for that about the cams, do I really need to worry about duplex when my oil pump will be crank driven (so must be a LOT less strain on the chain)? Bearing in mind how many engines are still going from factory fitted...! Obviously get rid of the nylon gear tho...
TVRleigh
Post by TVRleigh »
I would still change the chain, and maybe put a heavy duty one in, as all the covers I've seen have had marks on them where the chain has rubbed.
Problem is there still does not seem to be many people using the new covers to get much data.
