Rover V8 Engine Numbers Updated:
interesting stuff, thanks. i knew it was a low CR engine, didnt realise it was lower than the normal low CR though. as for millitary suffix' thats a lead worth following up me thinks. its asking for some sort of forced induction i reckon. fun fun fun!
I wish I had a pound for every time some one told me "My Dad had one of those!"
'78 Cavalier Coupe GLS 2000
There is a contact in Landrover who, for a small fee towards the landrover club will issue a letter that is acceptable to the SVA men in coats
(It worked for me in 2006)
Name
Eric Pagan
Traceability Systems
Land Rover
Lode Lane
Solihull
B92 8NW
0121 700 4524
Name
Eric Pagan
Land Rover
Lode Lane
Solihull
B92 8NW
0121 700 4524
newbie confused on engine numbers
just bought a v8 in bits to rebuild and drop into my stag got the heads off and checked the engine numbers
stamped rover
compression at 9.25 to 1 double checked this and got the wife to look as well,
engine number 48111686D
really confused can not see to makes this tally anywhere with info around on engine numbers.
Ben
stamped rover
Ben
Engine number 25G
25G 009670 i assume thats from sort off land rover? any pointers on that one? john
So thats where it went !
So, reading this thread and checking the engine number list given in the link, shows my new engine due to be transplanted into a 1978 manufactured '79 model year 280Z fairlady from japan, is a P6B engine off an Auto car.
On one side above the sump is cast:
4
BA 82291
613769
A
And behind the dipstick between the exhaust ports is stamped:
* 9.25:1 CR *
45114821 D
where the * are circles with some crescent marks in them that look like stylized propeller discs or spinning blades.
However, going by the list, a stamping starting with "451" ought to be 10.5:1 CR? and the danish guy on page one of this thread also had a 451 series with 9.35:1 CR ending in D rather than the List's "A" So does that mean 451xxxxx D suffix engines are 9.35:1 while 451xxxxx A suffixes are 10.5:1?
4
BA 82291
613769
A
* 9.25:1 CR *
45114821 D
I am trying to find a source of documentary evidence to prove the age of an early Range Rover engine with an ‘A’ suffix (3550****A). I know it was manufactured before August 1972 but I can’t find anything printed that says so. The Range Rover V8 engine numbers on the published lists seem to start at a ‘B’ or ‘C’ suffix. I rang the Gaydon Heritage Centre and they could not help - apparently there were no build records kept for the early Range Rovers.
Can anyone suggest an alternative source for this information?
Also, is there a way of confirming the compression ratio without taking the thing apart? I think it should be 8.5:1
3.9 engine number 36d29598b
It just says in the engine number list 1988 onwards.
Is this one of the late 3.9 engines with the cross bolt bosses and cross bolt caps? The guy assures me it's 1995 disco efi.
It's serpentine pulley etc with dizzy from what I can see of the photos...
There's something special about the suffix b I think.
