97mm head gasket?
kokkolanpoika
97mm head gasket?
Post by kokkolanpoika »
Hi..
Need info.
Witch side is top? I cant see any mark.. And "flame" ring is not identical..
Timo
Boosted LS1
Post by Boosted LS1 »
I'd fit them with the wide fire ring to the top as the flamefront/heat is in the head/chamber above not the block below if you know what I mean.
What brand are they?
russell_ram
Post by russell_ram »
Agree wide fire ring face to the top, but for a slightly different reason. The narrower ring will be sitting on the top on the iron liner. The wider ring will be against the aluminium head. Same contact pressure on both sides - obviously - but spread over a larger contact area on the head side to help avoid gasket sinkage into the head face.
Russ
kokkolanpoika
Thanks for info..
I bought them for RPI and dosen´t know more than that they are suitable for 96-97mm bore..
Timo
Boosted LS1
Don't Rpi know which way to install them?
kokkolanpoika
Boosted LS1 wrote:Don't Rpi know which way to install them?
Didin´t bother to ask.. :lol: Bacause i have got too mutch poor experience of their ability..
Timo
darren peart
Post by darren peart »
Rpi yes dont seem to know much about anything ,waste of time. :evil:
Rover v8 powered manta 9.6 @ 141 mph
Boosted LS1
I have a 5.1 turbo motor here with buick 300 heads and 96 mm bores. I'll probably order a set of those gaskets and I'll ask which way up they go.
If they can't tell me then I'll get buick felpro's and infill for the 'V' where I need to.
