I have got too mutch proplem with my engine oil system.
Engine is still my old RV8 4,6 stage 3 (buildin a new 5.2 engine)
My proplem is.
I bought new oil pump base last year (from RPI) and i drived about +3000km and relief valve sticks open position this summer. (same proplem as my old base, so i change new one)
So i take the base of and install some valve lapping stuf in it, add turn the pistons couple of times, and it moves like new again. But when i go to the test drive. valve sticks again slightly open. So i take it off again, and piston looks ok, but it will stick still.. (i also measure the clearances, bore is 15.25mm and piston is 15.21mm, so clearance is 0,04mm) i notice that piston will hit the wall when it comes out where the oil flows.. It will sticks there.
So this is not funny anymore..
Can some one explain why it will stick? Oil sump is clean, bearings are ok (look at them last year)
Can i solve this Fuc...ing proplem to fit tadpole??? I dont want to anymore bought +100£ base every summer or +3000km..
