Efi Wiring help
Awesome site you have here and thanks for the info, this should come in handy as i make the switch to EFI on my land rover. Do you have any other diagrams, like the color codes for all of the wires in this flapper diagram? If i am running an after market fuel pump that is mounted on the chassis and not in the tank, do i have to hook it up to the EFI system or can it run stand alone?
Chris
Chris
1982 Series III Stage 1
3.5 EFI
3.5 EFI
Run it off the EFI system and let the ECU turn it on or off via its fuel pump signal + relay. It's safer (IMO) than purely ignition activated.
VEMS New Zealand Limited
Versatile Engine Management Systems : World Class Technology. Global Support.
For UK sales, visit VEMS UK
Excuse my electonic ignorance but i have a few questions regarding your original instructions of what goes where?
Here is a photo of what is maybe the black/white wire you speak of that goes to negative side of coil? This one is blue/white but it is right next to air flow meter loom? Any ideas?
This is a photo of the only plug that i don't have a connection to on my truck or with the EFI bits that i have, i am assuming it contains the brown to battery +, the white red for crank side of ignition and white for ignition run position, an maybe even the purple/white for fuel pump? Am i close? Also, what are these two bundles that have been capped off?
This is the end of the loom with the ECU connection and some relays, i am guessing that this red and yellow wire was installed by the last owner as it looks spliced into the thick brown wire? Should i take it off, do i connect anything there?
Thanks for any info, i just want to do this right the first time.
Chris
Chris
3.5 EFI
3.5 EFI
landybob_v8
- Helpful or Confused
landybob_v8
landybob_v8
landybob_v8
also anyone got a 3.5 landy/range rover flapper wiring diagram i can add to the 3.5 car flapper and 3.9 hotwire diagrams
Cheers M.
From what I remember it controls the rpm signal to the ecu. On mine there is a vacuum operated switch teed in with the fuel pressure regulator which controls that relay. I think its a sort of throttle overrun fuel cut.
Deffinately control the pump via the ecu.
I used a jag pump which is external,mounted as low as possible and modified the tank pick up to use 10mm pipe.
The conversion is quite simple and most of the cables are right at the back of the engine in nearly the right place.
Alex.
Alex.
