rover v8 bearing caps
Hmmmm....
I've got a rover v8 that came already dismantled. However, I can't see any markings on the crank caps to determine which order they came out.
How critical is refitting them in their original order?
Also, this block has the lugs for the cross bolting (but "normal" end caps). Is it possible to get new "later style" end caps fitted and have the whole lot cross bolted?
Re: rover v8 bearing caps
Yes you can do that. And part of that process would be line-boring, so you'd sort out the main-bearing-cap issue you have (well, you'd ditch the existing caps!)volospian wrote:
Ah, I just cleaned a few up a bit and the first one I looked at had what appeared to be 2 cast lines, but after a clean they look like a 1 and an arrow. The rest have other marks, including what look like numbers and one with an F on it, I think. There's what looks like a 3 on one and a 4 on another...?ian.stewart wrote:They have to be matched, mismatch and you will kill the engine.sgould be marked F F2 R2 etc with an arrow pointing towards the front of the engine
Does that sound right?
I'll give them a proper clean tomorrow and see if I can get a better idea.
They will be numbered 1-4 with a arrow.
No 5 (the big end one) may nto have a number
Current V8 car TVR 400SE 240 BHP
Current Project TVR Tasmin Race, with 3.9 running at 230 BHP
Currently building a 4.6 300 BHP Xbolted Engine for it. Solid Lifters and Group A rockers, Stange 4 heads, Pocketed piston, fully balanced.
OK. The block itself looks nice. The bores look clean enough and undamaged. Everything, at first glance, appears to be fine, and there doesn't appear to be any cracking around the threads for the caps. I haven't checked for signs of fretting yet, but I imagine there could well be some anyway.
The old bearings are worn right down to the copper so I think the cank will need a regrind, so...
Is it worth getting new x-bolt style end caps fitted and the whole lot cross bolted and the crank bore line honed? The engine is staying at 3.5 as the bores are OK and I'm not after huge power to start with, I'd be happy with around 200.... but I am thinking of potentially a twin turbo set up at a later date.
I just wonder if it's worth x-bolting it while it's all stripped anyway, just to eliminate any possibility of fretting and/or cracking later. Any ideas on a price for this or is it just cheaper and easier to stick with studs/nuts and to buy a proper x-bolted block if I want to go that way later?
How much would a crank regrind cost, roughly? I see RPi are doing reground cranks for £128. For that price is it worth just buying one of those and chucking the old crank?
Also, with that in mind I'm assuming I could use a later 4.2/4.6 or something crank with new rods and 3.5 pistons, to provide a stroked 89.9mm engine? If so, what is the best set up, or is it just worth sticking with the shorter throw of the standard 3.5 crank?
If you have a 3.5 with the facility to x-bolt, it would be a good base for a turbo motor as the space between the bores is thickest (i.e. strongest) in a 3.5.
You could fit a later type crank by having the mains turned, or even the block, but it would require new liners and be a complete waste of time & money if you plan to stick with the 3.5. Usually the later type cranks are fitted to increase capacity.
And besides, if it is a 3.5 with xbolt facility, its a rare block and one that shouldn't be messed with apart from machining in the xbolts IMO!!!!
- HairbearTE
- Guru
chodjinn i've got one of those 3.5 x-bolt blocks. The cross bolt work is already done and has the small main journals. I was selling it last year but ended up keeping it. I was keeping it with thoughts of a hi-po future turbo engine but since I haven't even finished building my n/a motor then I think I should probably sell it. PM me if you're interested.
That's what I'm thinking, but there are what looks, in all the pics I've seen, to be the lugs ready for cross bolting.
Or am I getting it all wrong? Here's a pic of the "lugs"
and another from a different angle...
The Cam is not drilled for a thrust plate...
It's a stiff block...
You can see it's a bit shiney, this is, I assume, from fretting, but there doesn't seem to be any actual cracking around the bolt holes
It has the "standard" type caps, not those designed for cross drilling though
It's definately 3.5, so am I getting it wrong? Can it be cross bolted, or not?
lol, can you tell I'm a newb
Yeah, I meant to just increase capacity by stroking, but if it needs relining anyway, it is, as you say, pointless to stick with the 89.9mm bores.chodjinn wrote:If you have a 3.5 with the facility to x-bolt, it would be a good base for a turbo motor as the space between the bores is thickest (i.e. strongest) in a 3.5.
I'd rather keep it 89.9 bore, so it looks like that idea is out the window
- HairbearTE
- Guru
