Paul V8 wrote:Its now on there with no washers and all seems ok, i phoned Paul at V8 TUNER who said the same, no washers, maybe just a touch of thread lock.
Thanks.
Funny that you should say that your plate is OK as I've just fitted mine and the bolts hit the sprocket in a big way
My sprocket is a piper vernier jobbie and to get the bolts to clear I had to very carefully grind down the vernier bolts where they protude through the back of the sprocket AND grind the retainer plate bolts heads down until they where about 1.25mm thick.
Even now there is only 0.5mm clearance when the cam is pushed back as far as it will go. (measured this by poking bits of wire through the holes in the sprocket)
Why does every thing I go take 10 times longer than I planned?
(Two hours just to fit and time up the cam)
Oh, by the way I came up with what I thing is a good idea to stop the cam lobes scratching the bearings as you fit the cam.
I wrapped a strip of insulation tape round each lode and left a bit of the tape doubled back on its self so is could grab it with some needle nose pliers once the cam was fitted. Obviously the cam lobes must be lobed up after it has been fitted or the tape won't stick!
Regards,
Pete
