Making my own loom for the MS, using a hotwire manifold and injectors, coolant temp and bosch 2 wire IAC, so which plugs do i need form here?
http://www.vehicle-wiring-products.eu/V ... usings.php
i was thinking the 4145 with the 1900? thanks john
MS homemade loom
When I put my loom together, I used wire that has a lot of fine strands, its a low loss wire caled superflex?, and you get it from maplins, being flexible it resists fatigue breakages, only trouble with it is it only comes in Black or red, I got around the ID probs by printing off lots of little lables on the computer, and using clear shrinkwrap labled each end of the wire where needed,
Another thing I did was CRIMP all the wires and not solder any of them, soldering will cause a fatigue point where the solder ends internally in the wire, , I was even more impressed with my loom when a mate of mine who worked for Prodrive and now for Renault F1 as an electronics engineer told me the loom was "Spot on", only it was too heavy!!!!!, Ive seen some of his looms using aircraft wire and insulation so thin you would not think it could stop any form of current dissipating, more like the cellophane fag packets are wrapped in,
THE SMOKING GNU
bill shurvinton
- Getting There
Re: MS homemade loom
And 5962 the actual terminals.JSF55 wrote:Making my own loom for the MS, using a hotwire manifold and injectors, coolant temp and bosch 2 wire IAC, so which plugs do i need form here?
I used VWP too:
http://www.mez.co.uk/ms6.html
cheers Guys, i will write out a long list with a few extras to be sure, anyone tried those heat shrink type crimps?
So thats where it went !
im building a vems loom for stuball at the mo,
and im using non insulated terminals with heat shrink,
