I'd also like to have individual fuses for stuff like the fuels pumps, water pump and fan to take the strain off the crappy (i.e. basic) MGB fuese box (which has 4 fuses!).
Basically I'd like to know if this lot will work:
1). Two fuel pumps; run from the ECU (split line) and using relays; what I would like are two 'kill' switches or toggle switches to use on the panel. the idea is that i can turn the ignition switch on for power, then flick both switches to start/prime the pumps before starting the engine; they'd also act as kill switches in the event of a crash etc.
Could I run in-line fuses, one for each pump? What amp should they be? If not, what/how?
2) Manual switch for the water pump (EWP Davies Craig thing). Not using any thermostat or anything, just a power line to the pump and an 'on' switch. Idea is that i start the engine, let it warm up, then flick on the water pump.
3) Manual switch for the fan; same idea as above.
For all four of the switches above, I'd like a small light to indicate when they are 'on'. I've found loads of little lights to use, but do I need a specific amp/voltage, and how would i wire them into the circuit?
that's it for now . . . thanks in advance!
