Dannyb wrote:cheers for all the help
I work away all week so a freind is trying to sort it for me (technically still his car), will try steering module if the rr classic has one? The car was idling fine then it just stopped and refused to start since. It drove fine too only problem on entire car was rev counter had a mind of its own
Danny, the tacho uses the negative side of the coil for its engine speed input signal along with the same take-off point for the ECU trigger resistor/signal you referred to in your opening post.
This circuit shows the component #452 trigger resistor and you can see the WB wire that goes to the Tacho #95 from one side of that resistor.
http://www.vintagemodelairplane.com/pag ... uit01.html
If the tacho had been playing up, its possible that there is a wiring problem around the connections to the negative side of the coil.
Also you might wish to recheck that the resistor is 6800 ohms and is securely connected between pin 1 of the ECU and the negative side of the coil. That very hot area of the engine bay is hostile to efi wiring.
Might be worth a look.
The next thing I am not clear about so this is speculation: If the trigger resistor had previously been omitted, then that means pin 1 of the ECU and the input to the Tacho are joined together.
That is not as per the original design so a faulty Tacho might be responsible for hurting the ECU or Vice Versa.
Either way there is a common thread to these two faults as you describe them.
