Land Rover Brake Master Cylinder
Calling all 4x4 owners,
im after the land rover part number for a master cylinder used on the 2.25 series 3 i think its a 23.8mm bore one.
the lucas part number is: Land Rover 2.25 series 3 - 77-82 - Lucas no PMK177
i need the landy number to order one,
anyone help???
sowen
Post by sowen »
My parts cat. lists them as 90569126 (88in up to 1980) or 90569128 (88in from 1980 + all 109in), hope this helps.
Simon
1972 Rover 2000TC M16 turbo
1975 Land Rover OM606 diesel
cheers simon,
does it have any letters at the start like LRC etc?
sowen
Post by sowen »
There are no letters for the brake master cylinder part nos., unless the original land rover part has been superceded, which is very common in my experience. A good land rover specialist should recognize it immediately for you, even if its not a current number.
Simon
Hi Simon,
them numbers i gave were not what we wanted,
we want this one.
77-82 = 23.8mm bore tandem cylinder
not sure what its off landy wise though mate,
not sure if these numbers mean anything?
74066091
have found these master cylinders:
NRC8690
NRC9529
can't find what size the bore is though and what make if they are girling :cry:
sowen
Post by sowen »
I can't find 74066091 or NRC9529 in my landy parts catologues but I have found NRC8690 in my land rover 110 up to august 1986 cat.
I think it is the same as I have fitted to my landy and looks like this:
Don't know about the bore size though.
Simon
cimoss
Post by cimoss »
try this for size think it should give the info you need.....
http://www.shouieco.com.tw/index.php?act=bc&cy=20
chris
