I need to strip it down again, could anyone please tell me the torque sequence and values for when I put them back on?
Steve
I wouldn't do it this way. I'd stretch the bolts to the correct torque value otherwise they may slacken off and loosen the caps. Do it with a rod in the vice and then check for ovality. I've never had to resize a rod yet. That said, I haven't built a thousand engineskatanaman wrote: That said unless you have had the rods re-circled I would use standard settings as extra torque could pull the big ends making them oval and pinching the bearings.
